Hello,
I have the MB in subject working with a Corsair AIO H110i.
Evrerything is fine and temperature in idle are around 29 to 33 °C.
Even if the cooler works fine with its utility and the che CPU fan is read by MSI Command Center,
the motherboard has alwauya a red led lit close to the CPU fan header.
This is correctly (I suppose!) connected to the Y cable coming from the pump, made by a SATA power cord and a 3 PIN (but 1 wire) fan connector attached to he CPU fan header.
The question is, is it normal that this led remains lit all time in read?
I can't see error messages in the BIOS or in the various MSI apps and as the temps are good and the CPU fan fields show RPMs, I'd like to turn it off as it's quite unaestetic on my white build being the only red light.
Unless of course of having a trouble somewhere in my build I could not detect and fix so far.
Thanks, kind regards,
Alc
Alc
