Updated Razer Blade Stealth Sports 13.3-Inch Screen, Thinner Bezel, Kaby Lake CPU
Poozle
328
Looks pretty decent. To explain to the other commentators, integrated graphics are the only thing that will fit in a laptop this thin, it is called a thermal limit, and 150$ gets you a large battery that has the volts and AMPS to push power to a laptop. Something not many other batteries can do. Similar batteries go for 100+$ as well and those have sketchy parts to them as well. 500$ gets you into something niche that isn't for the masses. Not only this, but its extremely experimental yet. DDR3 V. DDR4 does not make that much of a difference, especially to someone typing up a word dock. This laptop is 900$, 300$ less then the macbook. Why are you complaining? you can throw the battery in your cart, maybe get a free mouse, get 100$ off the dock (if you simply MUST have it...) and still have extra money for more storage or other software.
