So I've been looking at PC cases for weeks now and i can't seem to decide on something, i'm making an enthusiast grade PC with custom water cooling and i can't find a case to fit all my needs exactly, here's the specs (https://pcpartpicker.com/list/GXJ4VY). with those parts in mind i have these requirements:
1. has to be white (can have black, blue or orange accents)
2. has to have a LARGE side panel window/tempered glass side
3. has to be big enough to fit 2 radiators, 2 reservoirs, 2 pumps along with the usual stuff for a PC
4. has to be well ventilated and filtered (I have cats)
So the build will have 2 custom loops with blue and orange coolant to match the theme of Portal (along with the case being white), I have found 1 case that i think will work (https://www.newegg.com/Product/Product.aspx?Item=N82E16811853032). with this in mind I want to know if:
1. will everything fit inside?
2. can the res in front be modded to be part of a custom loop? (i'm sure it can, i'm more asking if it's worth it)
3. this is my biggest question, can i modify the front reservoir to have two separate colors in the helix? (blue and orange); I know that the reservoir connects at the bottom creating the loop but i was wondering the viability of creating two exit holes so I can turn it from a complex U-turn into two spiraling straights
