T TrueOrigins1 Prominent Jun 20, 2017 3 0 510 Jun 20, 2017 #1 I recently got my new graphics card zotac gtx 750ti and ever since I got it I get no signal to my monitor but before when I didnt have it I did get signal what could be wrong? Im using a hp 6200 MT
Solution clutchc Jun 21, 2017 Is this like your HP 6200? https://www.neweggbusiness.com/Product/Product.aspx?Item=9SIV0365NK1621&nm_mc=KNC-GoogleBizMKPL-PC&cm_mmc=KNC-GoogleBizMKPL-PC-_-pla-_-Desktop+PC-_-9SIV0365NK1621&gclid=EAIaIQobChMI14Ob8Y7Q1AIVXbbACh1xogGEEAQYAyABEgLN3PD_BwE If not, please list your system's specs.
clutchc Titan Ambassador Apr 22, 2009 43,150 411 131,790 Jun 20, 2017 #2 Did you remember to move the video cable from the integrated graphics port on the PC over to the card's video port? Upvote 0 Downvote
T TrueOrigins1 Prominent Jun 20, 2017 3 0 510 Jun 20, 2017 #3 clutchc : Did you remember to move the video cable from the integrated graphics port on the PC over to the card's video port? No its just a plug in gpu and your good to go no 6 pin connector Upvote 0 Downvote
clutchc Titan Ambassador Apr 22, 2009 43,150 411 131,790 Jun 20, 2017 #4 TrueOrigins1 : clutchc : Did you remember to move the video cable from the integrated graphics port on the PC over to the card's video port? No its just a plug in gpu and your good to go no 6 pin connector Who said anything about the 6-pin connector? I'm referring to the cable from your monitor. Upvote 0 Downvote
T TrueOrigins1 Prominent Jun 20, 2017 3 0 510 Jun 20, 2017 #5 clutchc : TrueOrigins1 : clutchc : Did you remember to move the video cable from the integrated graphics port on the PC over to the card's video port? No its just a plug in gpu and your good to go no 6 pin connector Who said anything about the 6-pin connector? I'm referring to the cable from your monitor. Yes I did plug in the cable to my gpu which is hdmi then to my monitor but still no signal Upvote 0 Downvote
clutchc Titan Ambassador Apr 22, 2009 43,150 411 131,790 Jun 21, 2017 Solution #6 Is this like your HP 6200? https://www.neweggbusiness.com/Product/Product.aspx?Item=9SIV0365NK1621&nm_mc=KNC-GoogleBizMKPL-PC&cm_mmc=KNC-GoogleBizMKPL-PC-_-pla-_-Desktop+PC-_-9SIV0365NK1621&gclid=EAIaIQobChMI14Ob8Y7Q1AIVXbbACh1xogGEEAQYAyABEgLN3PD_BwE If not, please list your system's specs. Upvote 0 Downvote Solution
