EK Water Blocks (Finally) Releases A Gigabyte X370 Monoblock
msroadkill612
202
29
18,710
surely they dont really use water for coolant? The snap indicates not. Dumb name if so.
Speaking as a ~newb, would it not be better to spend a bit more on a modular cooler & also cool gpu & chipset & maybe nvme ssd?
Separately, i would think a simple fan on the underside of the cpu would have good effect?
durahl
26
It's usually ordinary distilled / demineralized water with additives to prevent corrosion / algae growth and sometimes pigments for colorization though I've seen some whacky stuff back in the days where people used liquid metal with special pumps for a shiny metal effect in their tubes / reservoirs.
Depending on what look you're going for a Monoblock can make things a lot easier.
Here's mine without one requiring 6 connections in total to do the job of some Monobocks only requiring 2: http://imgur.com/3bck03l.jpg
