Hi everyone,
I was hoping to get some help or opinion on a custom build before I order the parts. If the parts are compatible or if there's anything I should know. My goal was to create a mid to highish gaming pc that can run and perform well for most games. I also had a question on how I would connect my Dell SE2717H/HX monitor if I go with this build, since the motherboard has a DVI-D port, would I need to use an HDMI to DVI cable? wasn't too sure.
If you have any suggestions, changes or notice problems with the following build, please mention it.
Processor: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor
Mobo: ASRock A320M-DGS Micro ATX Motherboard
Memory: Kingston - 8GB (1 x 8GB) DDR4-2133 Memory
Storage: Western Digital 1TB 3.5" 7200 RPM SATA III 64MB Cache Desktop Hard Drive (Blue)
GPU: PNY XLR8 GeForce GTX 970 4GB GDDR5 Graphics Card
Case: DeepCool TX Mid Tower TESSERACT SW (Blue)
PSU: EVGA - 500W 80+ Bronze Certified ATX Power Supply
All help is appreciated
Thanks
Thanks
