Hi all.
I recently put together a new build (specs at the end of post) for gaming, recording and editing (just like every other 17-year-old these days ). I had originally planned to put in an EVGA 1070 and use an EKWB A240G to cool the GPU and CPU. But the EKWB kit sold out and the GPU rose in price. So, I instead upgraded to a 1080 Ti and am using an H55 for the time being.
I intend to overclock the CPU when I can afford the water cooling system and my problems should then be permanently sorted. But, today, I decided to run MSI Afterburner and watch GPU and CPU temps while gaming (did a maybe 3 hour session on Minecraft). During a rather heated battle, no pun intended, I glanced over at my temps and saw that my CPU temp had maxed at 77 degrees C (the GPU wasn't a problem - that didn't rise about 60 degrees!). I'm generally not happy when my CPU temp goes over 75 degrees, so playing a rather undemanding game such as Minecraft and getting those temps spooked me.
So after I went into my bios and reduced the clock speed (was, at the time, running at 4.6GHz) down to stock speed (4.2GHz) and changed my fan curve so that my fan speed increased as soon as temps hit 70 degrees. I then decided to run some stress tests. I ran Geeks3D GPU Test and Prime95 at the same time while Real Temp GT and HEiNFO kept me posted on temps....
My GPU ended up hitting 87 degrees, and my CPU 91 degrees (that was core #4, #1 88C, #2 88C, #3 87C) after 4 minutes of running the benchmarks! As soon as I saw these, I stopped the tests and got on here to ask, why are my temps so high? Is this normal when both GPU and CPU are running at 100% for an amount of time?
Regarding the GPU, I do have the power limit maxed out, and so the temp limit which (when not under load) gives me more FPS than when not maxed. And could it be that until I'm able to afford my custom water loop, I should get a better AIO cooler for my CPU?
Sorry for the massive post, and many thanks.
Specs:
i7-7700k @ 4.2GHz
MSI Z270 Gaming M7 Mobo
Gigabyte Aorus GTX 1080 Ti
G.Skill TridentZ 16GB Memory @ 1666MHz 15-16-16 (haven't yet figured out how to enable XMP - until I opened HWiNFO64 I was happy thinking my RAM was running 3333MHz)
Corsair H55 (fastened to the top of the case)
Corsair CS650M
Corsair 570X (w/ 3 SP120 RGB intake fans on the front, and 1 outflow on the back)
Samsung 850 Evo 500GB
Seagate 2TB HDD
Specs:
i7-7700k @ 4.2GHz
Corsair CS650M
Seagate 2TB HDD
