I've been using the pentium g3258 with gtx 750 for a little over two years now, overclocked to 4GHz... later underclocked to 3.8 GHz since it wasn't as stable anymore and upgraded to a gtx 960 4gb gaming. As of late the cpu has started to slow down multitasking and i think it is the cause to games crashing more frequently, it also thermal throttles a lot and i wont be upgrading to the DDR4 platform since money... im pretty torn between the (Core i5 4460) and (Core i5-4690K Devils Canyon).
Where i can get them both cheapest the 4460 goes for like 310 US and the 4690K 237 US but i will be needing a Windows 10 pro key and three Noctua NF-S12A fans since i still have the stock fans which are pretty loud... so 101 US for that those.
I can save like 72 US if i go with the 4460 witch can be used for savings but i need advise choosing.
I play games like dark souls 3 and fallout 4 in 1080p occasionally but would like them to run without crashing all the time and bee able to multitask as well. Four cores is more than i ever had, but will 3.2 GHz with 3,4 GHz turbo clock be enough speed wise or does 3,5 GHz with the ability to overclock work better? Would like to try mirror's edge catalyst at some point witch demands four cores.
Here are my specs in case im missing a factor:
CPU - Intel Pentium G3258 3.2 GHz anniversaary edition (Overclocked to 3.8 GHz)
GPU - MSI GeForce GTX 960 4gb
RAM - 4x2 gb "Generic" Crucial DDR3 1600 MHz 8 gb totall
MOBO - MSI Z97M-G43
PSU - Cooler Master G650M
SSD - Samsung 840 EVO 120 GB Samsung (10 % over provisioning)
HDD - Some old 2.5" Seagate drive for storage
CPU - Cooler - Noctua NH-U9B SE2
Chassi - Cooler Master Silencio 352 Mini Tower
NZXT Sentry mix fan controller (Since my current mobo doesn`t seem to work with speedfan as the old on did.
MOBO - MSI Z97M-G43
