I'm a console gamer, so I don't know if more than 60hz panel will make any difference for me. Also 1080p for 27 inch is a downgrade for me in terms of PPI. I would have gone with the TV but two things made my decision difficult...
First, the picture quality of the Quantum Dot panel with 125% sRGB, the feature that everyone is praising. However, the TV contrast ratio is roughly the double, 6362:1 according to rtings.com review and HDR at not bad brightness is a bonus. I would still assume the Quantum Dot will be better in term of overall picture quality and colors but how much better?!
Second, the monitor performance seems to be better with 1ms response time. I'm currently using S24D590L PLS monitor with 5ms response time and was coming from 1ms TN panel and I couldn't seem to differentiate between the two. I know my current tested response time should be higher than 5ms and the advertised specs isn't acurate. So I wonder if the tested value of 21ms on the TV will be much worse to tolerate. If yes then is there anything to do about it from the TV settings?!
This is the TV review
http://www.rtings.com/tv/reviews/samsung/mu7000
I'm planning to use whichever I buy for console gaming (casual and story driven games), movies and for computer usage, browsing mainly.
Btw... I know about the new Chfg70 monitor that is newely released with HDR and 2K resolution. But it might never be available anytime soon and in addition to that, there is also the 2k resolution that seems dated and the HDR isn't better than that on a mid-range TV.
