Good afternoon.
I will soon be changing my case and adding a full custom wc loop. My question here is what order to add components to the loop? The internet cannot seem to give me a straight answer when looking generally, so I figured asking about my specific requirement might be better.
I will be cooling the following:
CPU
Motherboard (x-chill on Asus Maximus IX Formula) (Not because I need to, simply because it is there)
1 x GPU
I will be setting this up on dual radiators with a separate pump and reservoir. At this point, I won't be looking to add anything else to the loop in the short term.
Thanks in advance
CPU
1 x GPU
Thanks in advance
