When I plug speakers/headphones into my front panel audio port, they are very loud and I cannot adjust the volume. When I use the volume mixer, it doesn't change the volume, but it still mutes at 0, which is weird because you'd think the mixer would also be working. Plugging into the motherboard works but I would prefer to use the front panel instead of the motherboard because of the short cable length. Sound drivers are up to date. The case is an nzxt s340 and the motherboard is an asrock ab350 pro4 if it helps.
