MY graphics card runs well when i install it after couple of days but when i use it for a while (30-60 mins) its staring system freeze,,i cannot do anything,it just freezes the whle system even in bios,,, i just use power button to force shut down .... and when i start it again the gpu fan spins crazy...... so i turned it off from power outlet... but after that gpu does not turn on ever.................. please help me...... my specs are
amd radeon r7 360 gpu
amd fx 6300 cpu
1th wd hdd
gigabyte 970a-ds3p mobo
corsair vs550 smps (new)
8gb ddr3 1866mhz kingston hyperx fury ram
my case is clean,, my temps are all normal.... even my gpu freezes when its only 45 degrees at idle after a while...
any help or advice would be appreciated
my gpu runs again if i install it after 3-4 days later.....
amd fx 6300 cpu
1th wd hdd
