At my place of work, we had a power outage for about 10 seconds. The entire building went off. All issues were fixed except 2 computers
Both desktops use multiple monitors. The monitors with VGA work, but the monitors with HDMI do not work (everything worked before outage). If I swap the cables and put the VGA into the monitor it works fine so the issue is not the monitors.
I had a similar issue after a windows update, so I tried to restore to a previous time but it did not fix it this time.
Also, on one of the computers, we have 2 label printers (hooked via usb). Ever since the outage, if I try to print to printer A printer B will print and printing to B will print A
Any Advice??
P.s. No dedicated graphics cards. All hooked directly to motherboard.
I tried to update drivers but all drivers said they were up to date.
Also, We are using all available VGA ports, so i cant just swap to VGA.
Please Help!
Any Advice??
Please Help!
