Ok i have a 2006 ford 500 and i recently hit something in the road busting the radiator thermostat housing condenser and cooling fans ive replaced everything and have no leaks but i noticed once the car warms up enough the cooling fans are in a high gear and they never use to run that fast the temp is staying normal on the gauge ive only got water instead of coolant in at the moment could that be the problem or something else
