I have 3 monitors, 1 is different out of all 3. 1 Samsung that can run 2k resolution and the other two that can run 1080p. I have put the same setting son the 2 monitors that are the same but 1 looks really good and the other one looks crap. But the main problem is 1 of the monitors that can't run 2k thinks it can but the monitor that can run 2k (my Samsung monito) doesn't have that option there! I have uninstalled the drivers tried everything loads in the display settings tried to configure everything and it still looks the same. Having 2 monitors that look fine and just 1 of them looking crap! So I keep that one off because my eyes feel like they're bleeding when I look at it for like 5 minuites. This is very annoying and I have loterwllly tried everything and nothing's changed. Apart from the fact that one is using a display port, my Samsung monitor is using HDMI and my other monitor that is the same as the other one (LG) runs from vga. I would love to have some feedback as soon as possible. If you want screenshots just email me thanks
