So i just got a new motherboard, new ram and new cpu.
i reformated and got the new parts in and it was running fine
however i've had a few cases of the screen not getting a signal when turning on the pc both from being completely turned off and just from sleep mode. (cpu and gpu fans dont run when this happens)
most of the times its happened i've turned the pc off and on a few times to no avail and then once i open up the side of the pc and tighten a few different cables on the motherboard (that by looks of it were not loose at all weirdly) and then it works on next start up (the cables are the ones from the case and a few psu ones)
however now theres been monitor problems three times WHILE the pc was running
first time i was opening a game while having a stream on the other monitor and it just lost input and i lost all sounds as well and i had to restart the pc a few times
second time also happened while opening a game and this time i had spotify on the other monitor then both monitors became a kinda yellow/orange color (similar to my background)
music from spotify was still playing this time and i then had to manually restart
third time happened withing 10 to 20 minutes of the second and this time it went yellow again while i was just searching something on the windows search bar
this time however the pc restarted on its own after a few seconds (i dont know if its important to note but it also had to install a small update when restarting)
i've also made sure that its not a heat issue as parts never get too hot when im playing games
my limited knowledge and searching leads to believe its either a gpu or psu problem but i dont know nearly enough to know wether those assumptions make the least bit of sense
i'll also note that both my gpu and psu are the oldest parts in the pc currently
gpu being about 3 years old
and psu atleast being older than the gpu
Specs:
motherboard: asus prime Z270-P
ram: corsair vengeance DDR4 2X8GB 3000MHz
cpu: intel core i7 - 6700k
gpu: asus geforce gtx 970 strix
psu: energon 750W
kingston SSD 120GB
seagate HDD 2TB
Specs:
psu: energon 750W
kingston SSD 120GB
seagate HDD 2TB
