Posting a fix for those who encounter this and are too stubborn too buy parts.
Things you will need:
1: Thumb tack (or needle of some kind)
2: Needle nose pliers.
Step 1: Remove the power cable from your computer. (safety first)
Step 2: Grab the cable and turn it over to the side that you can see the metal.
Step 3: Take the thumb tack and gently poke the metal while tugging on the individual wire. (poke closer to the side near wires)
Step 4: Once you have the wire out take the thumb tack and pop the clip you pushed down, back up a little bit.
Step 5: Now for the problem, take the pliers and squeeze the part that grabs the prongs on the graphic card. Keep doing that until the opening is just a little bit smaller than the pins.
Step 6: Push the wire back in correctly. Repeat this process until all 4 wires are done.
Hope this helps other cheap dudes like me.
