ViewSonic XG2530 240Hz FreeSync Monitor Review
RCPG
58
What about the ASUS ROG STRIX XG258Q and the Dell Alienware AW2518Hf? They are also 240Hz monitors with Freesync. Those two (Viewsonic and AOC) are not the only ones and I would like it very much if you could also review those to see which would be the 240Hz Freesync monitor king. I'm thinking about buying one 240Hz Freesync monitor and would like to buy the best. Currently have an AMD R9 390. Planning to upgrade to a Vega 56 or something like that, but only when that becomes affordable. The prices are just too high right now.
d--anderson
4
Let me know when we have 4K, 32", 120hz+ on a true HDR 10bit colour with 1000nits.
Oh wait, nothing of the sort is available until 2H2018. All we've got is garbage that 'supports' HDR signal input without actually displaying it.
ElMojoMikeo
38
A 24.5in 1080p is not exciting. To some degree it is obsolete. With 2, 3 and 4K becoming wider spread. The 3 and 4K display would need to be around 32in for daily use. You might get away with 2K at 27in just. So higher resolutions will require larger displays. I think we are seeing this trend as we move forward. I am guessing that a 30ins 2K monitor with free sync could be the new base line.
Jan 19, 2018
Those in favor of higher resolutions... I agree that higher resolution with HDR and 1000 nits of brightness is great, but this monitor is geared towards a specific market of very competitive gamers. Those who play FPS games, etc. If you want to drive a monitor up to 240Hz @2K, you'd need a tech that might not even exist yet. 1080p resolution is there for a purpose. I am sure there will always be a market for this kind of hardware. Just read Amazon reviews on a 144Hz monitors.
I have a 144 Hz monitor (on which colors and contrast look lile garbage) to play Rainbow 6 Siege on, and a separate 4K one so I can enjoy my Forza Horizon 3 in glorious 4K 60. 144Hz monitor gives you the ability to sharpen your skills if you desire to do so. Not everyone can afford that, but there is certainly a market for it.
ddferrari
388
6
18,865
Is this the "cool" thing to do now- proclaim that anything less than the ultimate *whatever* (that doesn't even exist) is beneath your high standards? Here are a few facts to chew on, which apparently you haven't thought about:
a) There's barely any HDR content in any format available right now. You do realize that feeding any old thing into an HDR monitor does not give you an HDR picture, right? The content has to specifically offer HDR support.
b) There is no GPU in existence that can come close to 4K 120Hz. Not even the first gen of Volta will be able to. Certainly nothing from AMD for years to come.
This dream monitor of yours doesn't exist yet for a reason.
ddferrari
388
6
18,865
So it's not for you, therefore it shouldn't exist? Really?
d--anderson
4
There's heaps of HDR media, even Dolby Vision content (12-bit colour). Many TV's are already capable of the above specs, but monitor tech lags behind tv's.
Not everything is about gaming, or I'd have mentioned input ms as well.
papality
74
the 1080p/240Hz market is so niche and silly that *yet another* edition of the panel probably shouldn't, no. Maybe if manufacturers would move past a resolution standard from a decade ago and put some effort into 1440p/144Hz, there would be more than a handful of actually decent monitors.
ddferrari
388
6
18,865
I'd imagine many 1080p/240Hz gamers would say the 1440p/144Hz monitor is actually the niche product here, as they require an expensive GPU that many people can't afford. Hamburger and filet mignon have coexisted for ages, so I don't see how 1080p is somehow holding back 1440p. It certainly isn't holding back other advances, like HDR and Quantum Dot.
Speaking of choices, I'm on a 3440x1440p/120Hz/Gsync/1900R/IPS monitor (my 1080 Ti has its hands full), and there are exactly two of those on the market. At least with 1440p/144Hz, Newegg has around 30 to choose from. Obviously, I'm not a 1080p fanboy- I just disagree that mfrs should start "herding" people into 1440p by fazing out 1080p. It's a big world and a big market; there's plenty of room for both.
alextheblue
I'm gonna act like the 4K "true" HDR (whatever that means one year to the next) elitists for a moment:
I declare that any monitor with lower than 240hz refresh rate is obsolete trash and should be discontinued. Call me when we have true 480hz displays.
See how that works? If the display isn't for you, move on. Every single time they review a gaming monitor we get the whiners deriding a product that isn't even targeted at them. Unbelievable.
