The power supply in my husband's PC, an old HP xw6400 workstation, went dead last night. It overheated to the point that the power cord has fused to the power supply and can't be removed. The power supply in the the machine is one made by Diablotek and it is a model PSEL500 500 watts.
I know this PC is old, but up until now it has ran fine, and we can't afford a brand new PC for him right now. I also know that this brand of power supply isn't very good but it is still available for only $19.99 from Microcenter. I don't know if I should buy a more expensive one in case other components in his computer were damaged when the power supply went out.
Should I just buy the same one? Or can you all recommend a slightly more expensive power supply that will work for around $30?
Thanks!
Thanks!
