Every 2-5 seconds, my audio stutters and makes a sort of choppy buzzing noise. It is sometimes accompanied by a bit of lag in the audio. The issue resolves itself temporarily when I restart my computer, but it doesn't take very long for it to start happening again: If I restart, usually the problem is back within half an hour.
I have been looking for a solution for months to no avail and have already asked on some other forums. I would really appreciate help.
This happens regardless of whether I use my headphones or loudspeakers, and regardless of whether I use the integrated amplifier or my PC's built-in headphone jack. To be sure it was actually my computer I even went as far as borrowing my brother's headphones, and it made no difference. I am absolutely positive it is my computer and not an issue with my headphones/speakers/amp.
I have been searching around on the web for a solution, and I have tried the following things (none of which have worked):
- Changed power settings
- Disabled RealTek and nvidia sound in device manager (since I can just play sound through my integrated amplifier)
- Changed bitrate in sound settings
- Turned off sound enhancements
- Tried different applications to play sound (Spotify, Chrome, Microsoft Edge)
I am not sure where to go from here and I would like some advice on how to proceed. In advance, thank you very much for your time.
Specs
Windows 10
64 bit
i5 6600K CPU @ 3.50GHz
GTX 1060
Specs
Windows 10
64 bit
GTX 1060
