I'm in the process of building a new PC, and one of the things I picked up was an LG 34UM61-P 34" super-widescreen 21:9 monitor.
The setup I'm replacing is actually one of two machines that are connected to a KVM switch and share a pair of 19" monitors. Both PCs use VGA connectors both in and out of the KVM switch.
Since I'm still waiting for parts to arrive for the new build, I thought I'd connect up the new monitor and see how it looked. The sales guy at the PC shop sold me a VGA to HDMI adapter, which I connected to the VGA cable coming from the KVM switch.
The result is "No Signal" regardless of which box the KVM switch it switched to.
Am I safe in assuming that neither of my old video cards support the resolution required for the new monitor? Or is the problem in the adapter? Eventually I want to keep the KVM setup, so I need to figure out how to get a signal through to the monitor that it can use.
