I am moving my build into the Lian Li PC-011 Dynamic case and my current water cooling pump won't mount anywhere on the front side of the case as it is currently mounted to the back of the case as can be seen in this image https://imgur.com/a/530GT
So I'm going to upgrade my pump/res combo also as I've been having leaking issues with this one. I will be using the bottom of the Lian case for the 2 SSD drives and I'm looking for a pump/res that can mount vertically and stand on the bottom of the Lian case just in-front of the fans and radiator (here https://imgur.com/a/MPyQIVi), uses SATA power, and if possible can have the tubing connect from the top and bottom like the loop that I currently have. The Enermax NeoChanger fits this criteria but it has some pretty mixed reviews about it having design faults, and the Thermaltake Pacific PR22-D5 fits the criteria, apart from it uses 4-pin Molex power. Also the EK pumps look good and you can get a vertical pump bracket, however all the EK pumps appear to be molex also.
Any help in a solution or finding a pump/res that is reliable would be very much appreciated.
