I bough a Dell 1440p 144hz monitor about a year ago. Since i've had it, it has had a "ghosting" problem. I only notice it when there is something moving across a color that it contrasts with i.e. black text on a white background. I'm not sure if this is actually "ghosting" as it isn't noticeable unless things contrast. I've also checked the DP cable and tried using another. Not sure if there is a solution, but i'd like to at least find out what is causing this.
