Hello, I'm looking to build a small form factor PC that is quiet, it will be used for mostly gaming and possibly streaming. The only part I am set on is this case https://www.ebuyer.com/819554-phanteks-evolv-itx-glass-mini-itx-case-black-cases-ebuyer-ph-es215ptg-bk.
My Budget is £1100 Without case. I would prefer the theme to be black. If overclocking will help then okay but if no then I'm not bothered. I prefer Intel but once again if AMD will 100% be better the I'll go AMD. Nvidia is my choice of GPU.
My retailer of choice is Ebuyer, I live in the UK.
I will be buying at the end of this month
No OS needed
Any other question feel free to ask, Thanks
Edit: If its any use I will be buying two of these monitors not part of the budget https://www.ebuyer.com/720851-acer-xf240h-24-full-hd-freesync-gaming-monitor-um-fx0ee-001
No OS needed
