Headphone AUDIO DO NOT Work on Newly Build PC
kevinzou442
Commendable
May 27, 2018
16
I recently built a PC with Windows 10. I downloaded all the drivers (including audio). When I plug in my headphones into the audio jack, the computer recognizes I plugged a device in, but I can't hear anything from the headphones. I went to my audio device manager and couldn't see the device I plugged in. I made all disabled and disconnected devices visible and still couldn't see it. I'm sure the headphones work (tested it on my phone) and I made sure the HD audio plug was secure. Any help?
SPECS:
Motherboard: ASRock B350 PRO4
CPU: Ryzen 5 2400g
RAM: Corsair Vengeance LPX 3000 MHZ DDR4
PSU: EVGA 50W White
Hard Drive: WD Blue 1TB 3.5"
MOBO Drivers Link (if needed): https://www.asrock.com/mb/AMD/AB350%20Pro4/index.us.asp#Download
kevinzou442
Commendable
May 27, 2018
16
I am using the front panel and yes, I plugged the HD Audio cable in correctly.
