Motherboard: B350 PC Mate
CPU: AMD Ryzen 5 1600(Wraith Spire Cooler)
GPU: PowerColor AMD Radeon VEGA 56 RED DRAGON HBM2 8GB 2 x HDMI / 2 x DisplayPort Graphics Card (AXRX VEGA 56 8GBHBM2-2D2HD/OC)
RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 2400MHz
Hard Disk Drive: WD Blue 1TB SATA 6 Gb/s 7200 RPM 64MB Cache 3.5 Inch Desktop Hard Drive
Solid State Drive: Samsung 860 EVO 1TB 2.5 Inch SATA III Internal SSD
Power Supply Unit: SeaSonic 650-Watt ATX12V/EPS12V SLI Ready CrossFire Ready 80 PLUS GOLD Certified Active PFC Power Supply SSR-650RM
Case: Corsair Graphite Series 230T Solid Side Panel ATX Compact Mid-Tower Computer Case
I've been testing overclocks on my CPU and I now know that I max out at 3.8GHz with 1.325v. However, I've been running Rivatuner statistics while testing it out on games like Battlefront II and the cpu will go over 80 degrees Celsius in a matter of minutes and will not go down. I've already ordered two more case fans. Will 2 more 120mm case fans be enough to keep it below 80 consistently? If not, should I get a liquid cooler?
Also, when you order the fan, does it come with the wire to connect to your motherboard or does it come separately?
