G gina.davis96 Aug 16, 2018 1 0 10 Aug 16, 2018 #1 My Monitor display is cutting off the left side of the screen when I use a vga connection. If I use hdmi it displays correctly.
Solution Dunlop0078 Aug 16, 2018 Then why not just use HDMI, I would certainly use HDMI over VGA if I had the choice. To answer your question it is likely just a bad cable. Have you tried a different VGA cable?
Dunlop0078 Titan Ambassador Feb 13, 2014 13,306 146 70,990 Aug 16, 2018 Solution #2 Then why not just use HDMI, I would certainly use HDMI over VGA if I had the choice. To answer your question it is likely just a bad cable. Have you tried a different VGA cable? Upvote 0 Downvote Solution
