I5-3570k 105ºC under load on water cooling HELP!!
Related ressources
- 79-80 Celsius Under Load Overlocked With Water Cooling? - Forum
- 79-80C Degrees Under Load While Water Cooled? - Forum
- I5-3570K @ 3.8GHz + stock fan = 80deg under load? - Forum
- WTS: Save >20% compared to DIY! Water cooled intel i5-3570k (4.7 Ghz) amd 7950 (1300/1715) custom gaming desktop computer - Forum
- CPU temperature changes rapidly ONLY under load? help! - Forum
Related ressources:
- ForumSolvedCustom Water Cooling Kit help
- ForumSolvedall you guys with liquid cooled systems help. (gpu water cooling)
- ForumSolvedNeed help with new water cooling build
- ForumWater cooling, gaming, rendering and bluray all for under $2200? You betcha!
- ForumIntel i5-3570K Ivy Bridge Water Cooled Gaming Computer
- ForumSolvedNewbie to water cooling please help!
- ForumSolvedWater-Cooling setup, need help!
- ForumSolvedClosed Loop Water Cooling Help?
- ForumBest water cooling options under 75 dollars
- ForumSolvedUpgarding cpu, need help with water/air cooling!
- ForumSolvedHelp water cooling
- ForumSolvedWater cooling in a gamma? need WC help
- ForumSolvedWater cooling, help picking out the pieces.
- ForumSolvedHelp with first water cooling rig. NZXT switch 810
- ForumPC Restarts itself under intensive load! Please Help!!!
- More resources
Read discussions in other Overclocking categories
. I recently built my first pc, equipped with an Asrock z77 extreme 4 mobo, 8gb g skill ripjaws ram, ocz 32gb ssd, EVGA gtx 660ti, i5-3570k cpu (overclocked to 4.2 stock voltage), and a corsair h80 cooler. I noticed that under load (prime95), the temps get all the way up to 105 celsius, and the cpu starts to downclock itself (according to Cpu-z). This worries me, as I have never heard of temps this high on water cooling and with such a moderate overclock. I used arctic silver 5 as my thermal paste, got Antec fans to replace the stock fans that came with the cooler. even under load the air coming out of the radiator is cold, very cold. Did I do something wrong with installing anything?
