jankerson :
What is the Nvidia Inspector profile?
Nvidia Inspector is a tool that appears to be an expanded version of something like GPU-Z (the initial GUI is very similar), but has another GUI you can expand which has a library of profiles for pretty much every game. It's a lot like RadeonPro for AMD, but MUCH more comprehensive.
It was originally designed for better SLI performance, but has evolved into MUCH more. Each profile has driver level tweaks to optimize performance. Even if the game is well optimized and it is of little to no use for performance, it has things like Force On for Vsync, for games that have crappy Vsync and resit external Vsync, an intricate framerate limiter, and even a "Power management mode" setting, which allows you to set it to "Prefer maximum performance" per game. The latter is much better than setting Windows to High Performance power plan, because it automatically disables when you exit the game. This means you can have both cool, quiet, low 800Mhz CPU idle while not gaming, and full power while gaming. That in itself is a Godsend in hot summer weather for those whom have no air conditioning.
Anyway, I was really just asking whether you guys were using it to make sure the great performance you're reporting was solely due to the game's optimization, and not an external tool. I mean that video I posted above was done on a 7700k and 1080, so you can see why I was skeptical when his had that severe frame drop.
[EDITED]
Just realized the guy that made that vid was using the Nvidia driver prior to the one optimized for this game. I asked him to record the same segment with the new driver, as his first comment stated he was going to try capturing with new driver, but didn't notice a difference in performance. I pointed out the 12:30 frame drop, maybe he didn't recall it or didn't experience it when not recording.
https://www.guru3d.com/files-details/nvidia-inspector-download.html
