M munna.4041 Sep 21, 2018 5 0 10 Sep 22, 2018 #1 Hello friends, would it be a good idea to use a LEDTV as a gaming monitor. If yes what all care should be taken
Solution Phillip Corcoran Sep 22, 2018 Fine as a general PC monitor but not for gaming (poor response times, scaling issues & blurry text are just some of the issues you may experience). http://www.tomsguide.com/answers/id-2569226/advice-computer-monitor.html http://www.tomshardware.co.uk/answers/id-3074718/led-panel-gaming-monitor.html
Phillip Corcoran Titan Moderator Sep 7, 2013 25,977 860 120,140 Sep 22, 2018 Solution #2 Fine as a general PC monitor but not for gaming (poor response times, scaling issues & blurry text are just some of the issues you may experience). http://www.tomsguide.com/answers/id-2569226/advice-computer-monitor.html http://www.tomshardware.co.uk/answers/id-3074718/led-panel-gaming-monitor.html Upvote 0 Downvote Solution
vMax Splendid Aug 7, 2006 3,445 353 25,690 Sep 22, 2018 #3 I am using a 50 inch, 4k 60Hz tv as a monitor and it works more than well enough...Unless you are a professional gamer, they are more than fine and you can find very low latency TV's as well...more importantly, I find they cost a lot less.. Upvote 0 Downvote
