So my monitor is not turning on, display is showing nothing, power light is blinking green and its making tick noise when it blinks. Its connected to gpu via vga->hdmi adapter(changed 2 of them).Cable is good(changed 2), gpu is also good because with other monitor its working alright. What can be cause of it? my bet is that its stuck in sleep mode or something is broken in video link part.
ALSO: its working when I take gpu out and connect it to motherboard. Also it works if after that I put gpu back int.
