Problem with Dell Monitor
Hi. I'm having a problem with my monitor and I hope you can help.
I have a Dell monitor, to be exact, this one: http://www.walmart.com/ip/Dell-IN1910N/11084592
The power went out for a second, and after that, I started seeing like these horizontal bars moving from the bottom to the top of the screen, where the screen gets a little bit darker. It's kind of like what you would sometimes see on older TVs when it got a bad signal.
To go through the obvious answers:
I connected another monitor to this computer and that monitor didn't have the problem.
I tried switching the cord, and that didn't fix it.
I've tried shutting down and unplugging everything for a bit.
I tried both outputs on the video card, they both had the same problem.
This monitor doesn't have a DVI input, it only has an analog input.
I'm not sure what else I could try at this point. So I came here! :)
1 answer Last reply
More about problem dell monitor
  1. That sounds like a back light problem. Your bulbs at the bottom may need to be replaced. Check with Dell Tech Support. They have always been good to answer my questions. www.support.dell.com
Flat Panel Monitors Monitors Dell Peripherals
