Display : Color Problem on my Samsung Monitor
gregg
178
I have Samsung SyncMaster 753s, 17 inch color monitor which is about 10 months old.
Recently it does not display the colors as it should. I can’t describe the problem technically but it seems like it is missing the RED Color.
Blues and Yellows are OK and every thing else as far as display seems fine and I am able to use it pretty much like a Black and Blue Monitor.
I really don’t like to send in for a repair because most products it always comes back with more problems and new parts stolen and replaced with someone else’s used parts where I live.
If something minor needs to be adjusted, I would like to do it if someone can give me some guidance.
Thank You,
Greg
jmecor
2,332
i use to have the same problem with samsung 17" inch flat-crt mopnitors.
<b>MY PC SPECS</b>
Intel P4 2.0GHz | 256MB PC2100 DDR SDRAM | Nvidia GeForceFX 5200 64MB | Integrated Audio | Asus P4S333 SiS645 | Seagate 40GB 7.2KRPM HDD | WIN98SE
jmecor
2,332
COLORS look DULL.
<b>MY PC SPECS</b>
abulkhair
my monitor had same problem, i send it to hardware shop for repairing but i don't think it works. Now my monitor have more problems....
G
Guest
Guest
Bad CRT. very common problem with samsung CRTs
