Mag monitor problems... need help
ok.. i have a Mag 810FD monitor. My problem is that when i turn on my computer, log into windows, and open up Internet Explorer, mozzila, or try to explore the hard drive, my screen goes black! i have waited up to 5 minutes and then i figured that i had to TURN OFF the monitor and then turn it back on! i have no idea what happened (this has been hapeing for about 6 months and i just installed a new HD and now its doing the same thing.
1 answer Last reply
More about mag monitor problems
  1. Your monitor may be dying.
    A guess and a test:
    When you are opening explorer or some other program
    you suddenly display a bunch of white on the screen
    which causes a surge of power to the flyout transformer.
    In this and some other components this surge causes the
    monitor to shut off (although power light is still on).
    Test this way:
    Do not open maximized windows for IE, Mozilla, or Explorer.
    Open them 3/4 or 1/2 size.
    See if that causes the shut-off.
    If not, then this is the problem.
    . . . and your monitor on its way out.
    CRT monitors have several components which
    deteriorate over time - and then die.
    Also, it is probably temperature sensitive.
    Hot - it will shut off.
    Cool - it will not shut off
    If the test above works, plan on a new monitor.
    Could last weeks or months . . . or days.
    You can also turn down the brightness and/or
    the contrast. Both affect the power surge which
    come from a full page of white.
    You may be able just turn down the brightness
    and stop the problem (for now).
    Please post the results of your tests here.
    Good luck.
CRT Monitors Internet Explorer Monitors Peripherals
