Monitor Power Problems?
I have a Optiquest v73 that flickers. It's not the refresh rate, because it is persistent even at +100MHz. I think that it is a power problem. The outlet I have it plugged into shares the same breaker as my fridge and microwave. When I turn on the microwave, the flickering gets much worse. So I think that it is a inconsistent power or insufficient power issue. Instead of using a cheap power bar should I buy a surge protector to fix this? Or will I have to buy a much more expensive UPS? Or is there a third alternative?
3 answers Last reply
More about monitor power problems
  1. Odds are this is NOT a power problem It is most likly a magnetic interferance problem. Move the system away from anything that creates a magnetic field like the microwave.
    Good Luck
    Jim at http://www.monitorsdirect.com
  2. Sometimes, if you have powerful speakers and they're right beside the monitor, they will cause this problem too.
    Rob
    Please visit <b><A HREF="http://www.ncix.com/shop/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/shop/index.cfm?affiliateid=319048</A></b>
  3. I bought a power-surge protector that had a EMI/RFI noise filter. That fixed it right up.
    Thanks for your suggestions.
CRT Monitors Monitors Power Surge Protector Peripherals
