Hi,
If anyone can fix my problem Il send them £10 by paypal, Its driving me mad and I dont know what to do apart from go out and buy a new motherboard which I shouldnt have to do.
Heres my machines spec :
AMD X2 4200+
AliveNF7G-HDready Motherboard
BFG 8800GT OC
4GB Matched Corsair DDR2
600w Thermaltake Toughpower PSU with Quad 12v Rails
2 x 250GB SATA Drive
Ok on XP everything runs fine and Crysis and Bioshock play very nicely and smooth with no problems.
My problem is with Vista, I can only install Vista when I disable my PCI express and run on the onboard graphics. As soon as I run the machine from the 8800gt vista either freezes completly on the loading screen or it says Windows has disabled the adapter as it is incompatible
Ive tried formatting both drives about 5 times, tried it on Vista 32 and Vista 64, tried taking some of the ram out, tried loads of different drivers, updated my bios, Ive tried everything I can think of and im stumped.
The only option I can think of is to get a new motherboard but I cant really afford it as Ive just spent out loads on the other bits.
PLEASE HELP !!!
AMD X2 4200+
BFG 8800GT OC
PLEASE HELP !!!
