Reply to this thread
Solved Forum question
Started by swegname | | 11 answers
I have a i7-4770K cpu and it came with a stock cooler. Is it okay to use it for a 4770?
swegname
July 22, 2014 6:59:14 PM
4Ryan6 said:
swegname said:
iceclock said:
yes its compatible sir but theres better ones out there for better thermal and acoustic reduction
Oh yes I know, I'm currently using a H100i. I just wanted to give my friend my stock cooler since his cooler seems so cheap and even worse than the stock.
Intel used to require you sending in the stock cooler along with the CPU if you had to RMA it, or your warranty was not covered, not sure about todays Intel CPUs but I've still kept mine, I suggest keeping it and let your friend buy his own cooler.
Mhm. I'll tell him that.
swegname
July 21, 2014 8:01:00 PM
swegname
July 21, 2014 9:28:21 AM
walterg74
July 20, 2014 9:40:30 PM
swegname
June 27, 2014 7:39:55 PM
See all answers
